Filament Tip Insert
I always have to cut the tip of my filament at 45 degrees otherwise the extruder cannot load the filament. Is there a way to eliminate this? I see that the Voron system uses the Enraged Rabbit Carrot feeder, which doesn't have a filament cutter, suggesting their extruder can load the filament without cutting the tip?
Napsal : 23/02/2022 4:06 am
RE: Filament Tip Insert
I don't think so. Whenever I don't cut it the nozzle clogs.
Napsal : 26/02/2022 1:40 pm
