Filament sensor wiring error
martin.s90
(@martin-s90)
Hello,
After assembling the printer, I can't get past the filament sensor test. I replaced all connectors several times and compared with the pictures,
but I think the cable is correctly placed. Also, I upgraded the firmware to the latest version in the hope that would help (no luck).
What more can be done?
(two pictures of filament sensor connectors included)
regards
Martin Sinot
Respondido : 09/07/2018 11:49 am
K7ZPJ
(@k7zpj)
Re: Filament sensor wiring error
Your photos are really blurry and taken at an angle so I can't really tell if you have the connector on right on the Einsy Rambo board or if it is shifted to to the left. The connector needs to be centered so that all 5 pins on the board go into the connector.
If that isn't the issue, I would contact support for help troubleshooting the issue.
Respondido : 10/07/2018 11:52 pm
mike.b24
(@mike-b24)
Just finished my build and got same error. Support sending new sensor. I asked if there were any instructions for replacing individual items and did not get a reply. Not sure how much disassembly is required to just put in sensor. I think I will take advantage of this and put a little grease on those bearings, was sort of regretting it after passing Step 5.
Respondido : 18/07/2018 2:03 am
