Filament sensor Issues
richardkwofie
(@richardkwofie)
When my filament sensor in my settings is turned on....i get an unload filament message and load filament message repeatedly...
unload filament.......i unload
then load filament i load......
then unload filament...
then load filament....in  a cycle and the prints never start
when i turn off the filament sensor in settings......my prints start and all is well
please any solution or idea why is so...i have latest firmware
Respondido : 25/07/2019 9:15 pm
RE: Filament sensor Issues
Is this mk3 or mk3s?
they use different filament selectors
if it's mk3, maybe  this idea will help? https://www.thingiverse.com/thing:3307739/files turn the sensor off, while you print the new parts...
if it's mk3s try re adjusting the filament sensor parts..
some folk have reported the filament sensor flag as being too long, or too short and modified it to suit. I have the mmu2s mk3s version, which has a totally different setup for filament sensing, which has not given problems, yet!
Joan
Respondido : 25/07/2019 10:23 pm
Dave Avery
(@dave-avery)
sensor adjustment is off. try  loosening the sensor pcb and moving it a bit . the flag that moves in the gap in the sensor is very sensitive . the actual sensing window inside the sensor is around 0.1MM square
Respondido : 25/07/2019 10:26 pm
richardkwofie
(@richardkwofie)
Thank you i have an mk3s
Respondido : 25/07/2019 10:38 pm
