[Résolu] Filament Load \ Unload when trying to print ASA
Josh Woodrow
(@josh-woodrow)
I loaded some brand new ASA filament this morning to print a new fan shroud. Preheat and loading the filament went perfectly fine. However, when I went to print the file (downloaded from the Prusa library) I ran into a weird issue where at the very beginning of the print it stopped and prompted me to remove the filament and then re-install the filament. I did this a couple of times but it wouldn't actually print anything. It just kept giving me this same prompt.
I did perform a cold pull right before to clear a clogged heat break but successfully loaded the ASA filament prior to the print job. I haven't had it prompt me to mess with filament unload and load before beginning a print before. Any ideas why this is happening? Did I mess a setting up during the cold pull?
Publié : 23/08/2024 5:28 pm
Josh Woodrow
(@josh-woodrow)
RE: Filament Load Unload when trying to print ASA
Turned filament sensor off and it solved the issue.
Publié : 24/08/2024 1:02 am
