Filament keeps leaking from nozzle
-_-
 -_-
(@_)
Hello everyone,
I have just assembled a new MK3s, and once i load the filament, it keeps coming out from the nozzle even after the loading process finished.
What can i do about this?
Regards,
Alen
Posted : 23/10/2019 3:58 pm
wieman01
(@wieman01)
RE: Filament keeps leaking from nozzle
Depending on the material you use and what temperature is pre-set, some oozing is to be expected. Once the print starts it will go away depending upon your settings. Try to lower the temperature as a starter.
If that annoys you before a print, you could add a "retraction instruction" to you G-code. The oozing will immediately stop.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Posted : 23/10/2019 4:57 pm
The only certain cure for ooze before printing is to reduce nozzle temperatures below the filament melt point.
Retraction is a temporary delay: ooze will still occur.
Oozing is made worse with cheap filament, moisture in the filament, oil on the filament (fingerprints make it very bad).
Posted : 23/10/2019 7:14 pm
Dave Avery
(@dave-avery)
even better you can modify your starting g-code to preheat to a lower temp during startup and then raise the hot end temp just before the pruge line is printed
Posted : 23/10/2019 8:32 pm
-_-
 -_-
(@_)
Thank you very much for all the helpful answers!
Posted : 24/10/2019 2:19 pm
