Fan shroud doesn't fit?
a.von.blumenthal
(@a-von-blumenthal)
Hi there, I assemled the mk3s and found that the fan shroud touches the heat block and is angled downwards, the claw of the shroud is below the nozzle height. I thought it was an issue with the shroud itself so I printed a new one in PETG and got the same issue.
Can someone advise what I might have done wrong? The shroud I printed was the last thing to print correctly as well but I will open a new thread for it as it seems to be a different issue (basically I get blobbing during print despite height calobration and live Z calibrations, the nozzle seems to extrude fine during the print but after a few blobs it stops extruding completely).
Photos  attached
Napsal : 16/07/2019 10:38 am
Lichtjaeger
(@lichtjaeger)
RE: Fan shroud doesn't fit?
Ähm..., why is your heat block 90° rotated?
Napsal : 16/07/2019 11:02 am
a.von.blumenthal
(@a-von-blumenthal)
Whoops
Napsal : 16/07/2019 11:14 am
