failed 4-point bed calibration - what do I do now?
higonnet
(@higonnet)
Having dis-assembled the hot end, I put everything back together and I ran the wizard. When I get to the 4-point bed calibration in which it is stated that I should turn the machine off immediately if the paper moves, the paper moves so I shut it off.
OK, so what do I do now? What are the likely things I should check/do?
Opublikowany : 30/09/2020 7:08 am
Peter M
(@peter-m)
RE: failed 4-point bed calibration - what do I do now?
Check the pinda probe if it is low enough.
Opublikowany : 30/09/2020 8:46 am
