Extruder wont go past 140 degree
Pathogen
(@pathogen)
After upgrading to R3 extruder, and also replacing long Teflon tube inside extruder, and replacing nozzle, MK3 will not heat extruder beyond 140 degrees, then reports PREHEAT ERROR. I have been cleared for replacement heat block, but seriously, any idea what is going on? Fails at 140 degrees each time? Also I reflashed firmware even.
EDIT: I will add that I was quite literally as careful as humanly possible as I had already read many people had broken wires handling the heatblock.
Postato : 15/10/2018 2:42 am
Pathogen
(@pathogen)
Re: Extruder wont go past 140 degree
As warranty replacement is in the mail I shall close this with the conclusion that somehow the heat block failed as there is no other possibility, like software or other electronics. The fact that the thermistor still reports a temp apparently means it can only be the heat block that failed.
Postato : 16/10/2018 3:30 am
