Extruder not heating
Bruce
(@bruce-6)
The extruder will not heat up, This is even after replacing the extruder kit. Cannot get the extruder to heat up at all. I have run preheat and the bed heats up alright, but the extruder does nothing but stay at room temperature.
What may be the issue? Is it a bad board?
Postato : 26/04/2018 8:54 pm
Re: Extruder not heating
fuse may be blown on einsy, this would normally give a thermal runaway error
heater - connector circuit may be open circuit , this would normally give a thermal runaway error
einsy may be faulty,
thermistor may be faulty / disconnected, this would normally give a mintemp error
selector button may be faulty,
Postato : 26/04/2018 9:41 pm
Bruce
(@bruce-6)
When I run the self test I get the following error
"Heater\Thermistor not connected." I have tried 3 different Thermistors and I get the same results from all three, they show room temperature. I have installed a brand new extruder kit and have the same results. I think it is the Rambo board itself
Postato : 29/04/2018 5:50 am
have you checked the fuses?
Joan
Postato : 29/04/2018 10:39 am
