Extruder Motor running Hot
Sink
 Sink
(@sink)
Was wondering if there are any causes to investigate for an extruder motor running hot?
Thanks in advance
Respondido : 09/05/2021 7:57 am
RE: Extruder Motor running Hot
How hot?
It's working hard, it will get warm.
Outside of an enclosure it should never get too hot to touch but it might be uncomfortable to hold.
Respondido : 09/05/2021 10:56 am
50c is not abnormal - mine has been as high as 58c in a 23c room.  I added a 40mmx40mmx11mm heat sink using thermal tape to the end of the motor. The motor case now sits below 40c most of the time.
https://www.amazon.com/gp/product/B01HSBM72W
- the pads in this set are not adhesive, so buy some thermal tape ...
https://www.amazon.com/gp/product/B01MSL64XG
Respondido : 09/05/2021 11:22 am
MadPrints3D
(@madprints3d)
Ive heard stepper motors run best hot. Anyways, its fine. If your worried people have made fan mounts for the extruder stepper
Respondido : 10/05/2021 4:43 pm
Dan Rogers
(@dan-rogers)
new firmware has a default-disabled option that can lower extruder 10c
Respondido : 11/05/2021 3:47 am
Miembro
I would not worry about it.
Respondido : 11/05/2021 2:36 pm
The heat from the stepper motor transfers to the drive and can cause problems when transporting PLA, especially when printing in an enclosure. I was able to lower the temperature from 55 to about 40 degrees C. with the installation of an noctua fan.
Respondido : 11/05/2021 6:44 pm
My post above is a bit optimistic - I meant to say it is below 50c now, when it was as high as 58c.
Right now, in the middle of an 8 hour print, the motor is running 46c.
Respondido : 11/05/2021 8:46 pm
