Extruder moter is rotating in the wrong direction
Germans Gruseckis
(@germans-gruseckis)
Can someone please help? I just finished assembling my MK3 and all was fine until I tried to load filament.
Stepper is rotating in the wrong direction insread of pulling filament in it is pushing it out.
I've updated firmware to latest and triple checked all wires - they are correct also motor is right as well.
Is there a setting that I can set to change motor rotation direction or should I do something else.
Please help I've spend all day assembling it and now I can even do a simple test print 🙁
Thanks in advance.
*EDIT* Just did some more testing and it seems that extruder only moves in one direction when you try to load or unload filament
Opublikowany : 11/12/2018 3:05 am
jvolkman
(@jvolkman)
Re: Extruder moter is rotating in the wrong direction
Try Prusa's 24/7 support chat.
Opublikowany : 11/12/2018 7:59 pm
