[Resuelto] Extruder doesn't move up after print finishes
J3ron
(@j3ron)
So i've printed my first "self" sliced object with my new MK3s.
But after the print finishes the head only moved back to the left, not up, so unless i move the z-axis manually I cannot get the steel sheet off of the printer.
Is there a setting or a command that moves the extruder to the top? My home is apparently front-left ~2mm from the build plate.
Best Answer by --:
You'll need to modify the custom gcode to do the final move as you want it.
Stock gcode looks something like this: move Z up 30 mm.
G4 ; wait
M221 S100
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
G1 X0 Y200 F3000 ; home X axis
M84 ; disable motors
You can change this line as follows:
G1 X0 Y200 Z210 F3000 ; home X, push bed forward, raise Z to limit
Respondido : 31/07/2019 4:00 pm
RE: Extruder doesn't move up after print finishes
G4 ; wait
M221 S100
M107 ; turn off fan
Esta publicación ha sido modificada el hace 7 years 2 veces por --
Respondido : 31/07/2019 10:04 pm
J3ron
(@j3ron)
I hadn't added the printer in Prusa Slicer - so no custom g-code settings. All default settings.
Got the Prusa settings added, and looks like everythings good now.
Thanks for the help
Respondido : 31/07/2019 10:31 pm
