Einsy enclosure and Heated Bed cable clip issue
snoOZer
(@snoozer)
Hello,
I was so lucky to receive my Kit yesterday and went through the assembly easy enough, thanks to the EXCELLENT documentation ! I came across a problem at the very end. When I try to close the door of the Einsy board enclosure it seems there is a cut out missing or the Heated Bed cable clip is somehow out of shape. The doors long upright corner opposite the hinge will not get pass the clip without deforming badly. I would be unable to use the long bolt to close the door. Have I misunderstood the directions/instructions at some point ? Please see the pictures attached for a easier understanding of my small problem.
Any help is appreciated !
Have FuN!
Jan P.
EDIT: Just noticed the attached pictures don't show, I try a link instead:
https://drive.google.com/file/d/1TNgrVjvsEk496eseMO65g0R1nIzr7fOw/view?usp=sharing
https://drive.google.com/file/d/19PeVsPqhcZyeyilS6fx1rPfL1W_bcVJy/view?usp=sharing
Veröffentlicht : 09/10/2018 10:46 am
stahlfabrik
(@stahlfabrik)
Re: Einsy enclosure and Heated Bed cable clip issue
You are trolling? 😆
Otherwise you might turn that part 180 degrees
Also: I tried to assembled it wrong like you did but could not because it does not fit. You must have used a lot of force to get it in:-)
Veröffentlicht : 10/10/2018 2:25 pm
snoOZer
(@snoozer)
Yes that sounds plausible now and makes sense, I give that a shot. It did however not require an unreasonable level of force. Thanks for stating what should have been obvious to me.
Have FuN!
Jan P.
Veröffentlicht : 10/10/2018 2:38 pm
stahlfabrik
(@stahlfabrik)
Have fun too! You are now very close to finish the build! Exciting times!
Veröffentlicht : 10/10/2018 3:20 pm
Martin E
(@martin-e)
Had the exact same problem - working from 'the book' with its tiny photographs and poor contrast is almost bound to lead to issues like this
Veröffentlicht : 24/12/2018 10:47 am
