Do y'all know why I am getting these blobs in my print?
theDSK
(@thedsk)
Hey y'all,
I have a Prusa Mk3S+ and I am printing PLA @ 215 C nozzle and 60 C bed temperature. I recently had to replace the nozzle because it was too much to clean and unclog it.
The good news is the printer is working again. The not so good news is that I am getting these weird blobs in the print and I have no idea why.
Would love to hear your thoughts!
Napsal : 18/09/2021 6:54 pm
Please show us a picture of your nozzle installation.
Napsal : 18/09/2021 10:52 pm
Swiss_Cheese
(@swiss_cheese)
@thedsk
based on your image and description of events there is a High likelihood that your nozzles isn't installed properly and is leaking around the heater block.
Regards
Swiss_Cheese
The Filament Whisperer
Napsal : 18/09/2021 11:02 pm
theDSK
(@thedsk)
You may be right
I changed the nozzle out with a different one which had a different shape and it was a pain to calibrate the z offset again. I have been researching as well and you may be right, it could be the leakage.
I have ordered these and will install them as soon as they deliver https://www.amazon.com/gp/product/B086W25579/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Napsal : 18/09/2021 11:14 pm
theDSK
(@thedsk)
the hotend was a bit loose
Here you go. I realized the heating block came undone when I was installing the new nozzle. I have tightened it now and started the print again. Will report back.
Posted by: @diem
Napsal : 18/09/2021 11:35 pm
theDSK
(@thedsk)
Figured it out.
Apparently the nozzle I installed is not compatible with the hotend and hence the filament is oozing out of it. Waiting for the compatible nozzles to be delivered.
Napsal : 19/09/2021 12:50 am
E3D hotend assembly guide is good
Raise Z so you can get a good look and remove the part cooling fan and inspect the top of your heater block. Look for a puddle of filament at the top of the block and likely dripping down the sides. If you see that, you definitely have a filament leak due to improper nozzle tightening. The E3D hotend assembly guide is very good. Pay careful to the bit about screwing in the nozzle flush, backing it out to the desired < 1mm gap, THEN hand-tightening the heatbreak up against the nozzle. The important bit is that, when properly tightened, it should be impossible to tighten the nozzle flush up against the block.
Napsal : 19/09/2021 3:15 am
RE: One of two things:
One of two things:
  1. Nozzle is not tightened against you heatbreak.
  2. Your heatbreak is not inserted far enough in the heat block to allow the nozzle to close the gap.
Napsal : 19/09/2021 11:17 am
Swiss_Cheese
(@swiss_cheese)
@thedsk
I'm glad we were able to help, this should be a fairly easy fix, I have found it best just to stick with the Genuine E3D nozzles they are reasonably priced and no quality or compatibility issues in my experience, on amazon you will sometimes find counterfeit products, so watch for that.
Looks like Bob, and Charles have provided you with some good info for the new nozzle install, you should be all set when the new nozzles arrive.
Good Luck,
Swiss_Cheese
Napsal : 19/09/2021 3:41 pm
theDSK
(@thedsk)
You are right about both. At first, I noticed the heat lock being loose so I cranked it down and I am still having those blobs so I am thinking it has to do with the incompatible nozzle.
The compatible ones will be delivered tomorrow. Will report back soon!
Posted by: @cwbullet
One of two things:
Napsal : 20/09/2021 3:12 pm
theDSK
(@thedsk)
Realizing the difference in the nozzle types the hard way
The nozzle on the right is from the Prusa
Napsal : 20/09/2021 3:17 pm
the nozzle in your picture looks like a Mk8 nozzle, which has a shorter screw thread and a longer nozzle... they can be made to work, at a pinch, but it's not really worth the effort.
there are many nozzles manufactures specifically for the e3Dv6 hot end
I have successfully used e3D, OEM nozzles,
Cheap as Chips chinese bulk  Brass nozzles
Chinese stainless nozzles, and I am currently using Nozzle Z, which is a cost effective hardened nozzle https://zaribo.com/nozzles/471-5006-top-quality-hardened-175-nozzle-for-e3d-v6-by-zaribo.html#/87-nozzle_width-04mm.
If you are considering trying different size nozzles I suggest you stick to 0.25mm, 0.4mm, 0.6mm and 0.8mm, because Prusa Slicer has preset profiles for these values.
Napsal : 20/09/2021 4:19 pm
