Different shine on the exterior wall
Hello, I have a problem with the outer layer.Well, every now and then I have alternating matte and glossy stripes.
I installed a new version of the Prusaslicer and replaced the brass nozzle with hardened steel and a new bimetal with a heat baffle.
The geometry is okey, the print quality is ok too, only this coating. I used easy Pla from fiberlogy. Plx help
Veröffentlicht : 04/04/2022 3:06 pm
Does it cause problems with paint adhesion? A little more sanding and a second coat of primer should cover it.
Veröffentlicht : 04/04/2022 9:44 pm
