Debugging and Calibration
NMR_Scientist
(@nmr_scientist)
Hello. Not new to 3d printing, but I am having trouble with calibrating my 3d printer.
Specifically, it seemed that it seemed that the hot end had grooved into my print bed. Or maybe it's plastic? I definitely felt the grooves. I tried cleaning it with isopropyl alcohol, but it doesn't do anything.
Here's the picture below:
Grooves in bed?
Also, I am pretty sure that the superPRINDA is below the printer nozzle, though I am going to be checking to be sure.
Postato : 30/07/2021 1:20 am
NMR_Scientist
(@nmr_scientist)
Cleaning drill bit inside the nozzle?
I think I know what's going on! I think the cleaning drill bit that I used got stuck in the nozzle. Working on removing the nozzle to see if it contains the drilling bit.
The idea occurred to me when i was attempting to clean the nozzle with one of the drill bit I purchased, and the end disappeared, presumably into the nozzle.
Postato : 30/07/2021 1:42 am
Dan Rogers
(@dan-rogers)
Yikes.
The old drill bit in the nozzle trick.  Gotcha.
Postato : 30/07/2021 1:12 pm
