Dead in the water
master moccasin
(@master-moccasin)
Dead in the water
I received my i3 MK3 on the 7th of June and took about 7 and a half hours to assemble it. It passed the initial check and I ran several prints over the weekend with black and white PSA and all are much better than anything I’ve ever seen from any of my printers. I could not be more pleased and agree with whoever said it was hands down the best printer for the money. Today I decided to change to ASA for some production parts, the reason I bought the printer, and it went badly. I followed the procedures as laid out by Josef in his video and elsewhere. The PSA would not come out and now I have a major clog. I am unable to clear it no matter what I do. In desperation, I disassembled the entire extruder section and found the clog is in the hot section between the nozzle and the heat break. The ptfe tubing was stuck and was stretched when I removed the cold section. The nozzle will not come out of the heat block and the small screw holding the heating element striped when I tried to remove it. I had first heated the assembly with a heat gun before trying to remove both. I am very disappointed that the printer works so well and now only a few days into printing I am dead in the water. I see the hot section is available but shipping is from 19 to 39 days. Are there any parts available in the US? Otherwise, is there a replacement hotend that will fit without modification?
George
Postato : 13/06/2018 2:59 am
Joe Prints
(@joe-prints)
Re: Dead in the water
The hotend should be available at most 3d websites (like MaterHackers). It is an E3D 24v variation with the 40 watt heater cartridge.
I believe Prusa uses a different heat break in their originals to boost volumetric pressure- I use a regular titanium one and it works just fine.
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
Postato : 13/06/2018 5:10 am
