Curious OBJ / STL slicing differences
Martin Stoufer
(@martin-stoufer)
This was my first end-to-end project from Fusion 360 to my MK3. I was all excited to try the built in OBJ export functionality in Fusion. After a clean import into Slic3r PE and a stock slicing (just with a different infill pattern at 15%), I noticed that the chamfer along the outside has a rather odd serration/tessellation on its surface. This was not part of the initial model nor did it show in the overview of the object in Slicer pre-slicing. I went ahead and printed it out to see if this was real, or just an artifact of the OBJ import:
Even the surfaces were a bit rougher than objects in STL format I've sliced in the past.
However, this effect is neat if desired, and I'd have no idea how to model it if I had to!
Now, from the exact same model in Fusion, I do an STL export and go through the same process as above. After slicing, the chamfer surface appears continuous as expected:
That surface is smooth as buttah!
Questions moving forward:
  • Is this due to a defect in the OBJ export of Fusion or an import/slicing issue with our Slicer? I'm happy to get all intermediate files for this to Prusa Engineers for analysis if it would help.
  • Is this an expected behavior/deficiency inherent with OBJ formats?
  • If there are knobs to tweak that are deeper in Slicer to resolve this, I'd be interested in knowing what they are.
    Veröffentlicht : 12/09/2018 10:12 pm
    Re: Curious OBJ / STL slicing differences
    Hi Martin,
    looks like the top picture is produced at a lower quality / lower polygon setting.... I have never used the .obj export so can't help further!
    Veröffentlicht : 12/09/2018 10:26 pm
