Crash Detection doesn't home - it homes to center and x/y axis coordinates are off
MotoGSXR
(@motogsxr)
I'm seeing Crash Detection about 1hr into a 20hr print. I saw it occur and it actually didn't crash into anything, crash error shows it was on the x axis. When the crash detection error is shown it doesn't home x/y to the front left corner, instead it homes to center and x/y axis coordinates are off. The print is then all shifted right. Has anyone else experienced this?
Ce sujet a été modifié il y a 6 years par MotoGSXR
Publié : 17/01/2020 8:00 am
MotoGSXR
(@motogsxr)
RE: Crash Detection doesn't home - it homes to center and x/y axis coordinates are off
I tore the x-axis apart and found that the bottom bearing has some stiction when rolling side to side, guess it failed. Sigh...3 day old printer and more problems than my CR10S.
Publié : 17/01/2020 8:47 am
@dan-byun
did you lubricate the bearings from new?
Publié : 17/01/2020 10:23 am
MotoGSXR
(@motogsxr)
@joantabb
No, per the instructions the bearings didn't need to be lubricated as they were already lubricated and the included lubricant is intended for maintenance. I don't know if it is the lube or if the bearing itself has failed somehow. I still need to take the bearing off the linear rod to take a look at the inside of the bearing.
Publié : 17/01/2020 5:17 pm
Ah well, you can use it now, as you are now doing maintenance...  😉
Personally I have always Lubed from Day one....
I don't know why Prusa say not to lube...   it's a bit like expecting assembly lube to protect your race car engine without additional lube...
Publié : 17/01/2020 6:13 pm
rmm200
(@rmm200)
Very likely your three day old bearings are fine.
If the bearing mount screws in the extruder are too tight - it will cause this. Loosen them a bit.
And don't believe the instructions - and probably don't use Prusa grease. Get a good bearing lube - and lube them properly.
Publié : 17/01/2020 9:27 pm
MotoGSXR
(@motogsxr)
@joantabb
LOL you're probably right, should have lubed them anyway.
@robert-rmm200
I did loosen everything and found that the bearing, without it mounted, was still sticking. I lubed it and now it moves mores freely but still feel some slight resistance to it. I was able to get it to successfully print something but ordered replacement LM8UU Polymer bearings just in case.
Publié : 17/01/2020 11:34 pm
rmm200
(@rmm200)
Don't use your polymer bearings until you have a reason to. Enjoy your printer now that it is working well.
Publié : 18/01/2020 12:10 am
1 personnes ont aimé
