Could you please judge my print? Z axis (imho) not optimized
PrusaNewbie
(@prusanewbie)
Hello everyone,
I bought a used mk3s printer. The printing works, but I'm asking you to judge the photos to help me understand where I need to do maintenance.
In my opinion, it's the height of the Pinda. I think I need to lower the probe closer to the plate, but I'm not sure. I'm printing with the Z axis at -0.6. In one photo, you can see the result first at -0.8, then at -1.1, and as it currently stands at -0.6.
The belt tension is low, so that will be the next job.
I want to place an order on the Prusa website and need to understand which spare parts to buy.
I have noticed that when printing with PLA on a steel sheet plate, I find it difficult to remove small pieces (e.g. the holland mill knob visualiser broke).
Please bear in mind that I am not very interested in the aesthetics of the print, as long as the piece is sturdy and durable.
Here are my print parameters:
Nozzle 0.8 brass no brand
Polyterra Pla blu
Belt status
X 242
Y 255
Belt test X : too lose 75/78 MHz
Belt test Y : too lose 79 MHz
Total statistics as I bought:
8000m
164 days
This topic was modified před 3 months by PrusaNewbie
Napsal : 08/02/2026 2:43 pm
All of your first layer examples are too low, too much squish.
But 0.8mm nozzles are pushing the capacity of the Mk3, you will gain very little benefit over a 0.6mm whilst risking under extrusion on long parts.
Napsal : 08/02/2026 9:00 pm
PrusaNewbie
(@prusanewbie)
RE: Could you please judge my print? Z axis (imho) not optimized
Thank you Diem for your feedback. I will add a couple of 0.6 nozzles to my shopping cart, thank you!
My plan now is to use a smaller cable tie and lower just a bit the Pinda sendor, as explained in the Mk3 user manual. I hope this will enable me to achieve Z parameters that are more similar to those I read about in the Prusa manual and Prusa video ( around -1.00 for and optimal print). I hop I correctly understood the work to do. 🤓 👍
Thank you!
Napsal : 09/02/2026 5:48 am
