[Risolto] Could fix my click issue with thermal paste on heat block
SPTNQ.com
(@sptnq-com)
Dear all
I don't have a question but I would like to tell some guys another trick that solved the clicking issue. I was going nuts and wanted to find out how to get rid of that mk3s. It's not my first printer but I run into issues since beginning. In the first night having it, I produced a blob of filament. That big that I had to replace several parts of my hotend, including some plastic parts that I printed on my other printer. That left many many possibilities why my printer started to click around instead of printing. Despite all the talks about the bond tech, I was sure it was a hotend issue but couldn't solve it - until today. I took some arctic silver thermal paste (usually used for CPU's on computers) and added it to the heatbreak . After hours and hours of searching, I saw a video about E3D where they talked about adding thermal paste. Well, that was the last thing I hadn't tried out. And now, the printer works like a charm. I hope this post can help some of you.
Postato : 12/06/2019 1:32 pm
1 persone hanno apprezzato
RE: Could fix my click issue with thermal paste on heat block
We're probably going to see more "extruder clicking" posts as summer approaches in many parts of the world. This is one of the commonly cited problems that seems to be related. Thanks for sharing.
Postato : 12/06/2019 2:44 pm
Markus
(@markus-10)
Were you able to extrude at all, or was your extrusion very weird and almost “laggy”.? I’m currently facing the same issue, and v
can’t even print, as it starts before the purge line.
Postato : 14/01/2022 5:21 pm
Markus
(@markus-10)
Postato : 14/01/2022 5:39 pm
SPTNQ.com
(@sptnq-com)
I don’t remember but I think it was as you describe. Thermal paste is not that expensive, just try
Postato : 14/01/2022 6:05 pm
Markus
(@markus-10)
I know, i just picked up some rated for 280c and will try in about an hour, i was just wondering. 🙂
Postato : 14/01/2022 6:06 pm
