Consistent layer shifting on new Prusa
FocusOnTheSun
(@focusonthesun)
So my brand new assembled Prusa is having some weird layer shifting issues. Upon closer inspection a few minutes ago, it may potentially be the bed axis direction only - but the weird thing for me was that it's consistent shifting between prints, see below where all the layer lines are in the same place!
I tried tightening the X belt which had no effect - but will try the bed axis, but incase that doesn't work, any suggestions?
Best Answer by Neophyl:
Other usual cause is the pulley itself. A lot of people fail to tighten the 2 grub screws correctly, if they aren’t done in order properly then they work loose. Doesn’t matter what the belt tension is if the pulley moves on the motor shaft.
Opublikowany : 06/06/2022 5:41 pm
RE: Consistent layer shifting on new Prusa
Opublikowany : 06/06/2022 6:11 pm
FocusOnTheSun
(@focusonthesun)
Doh! Great point, just checked and the pulley was indeed slipping!
Printing a benchy now to test, but if I don't post back, assume that it's fixed - thanks for the help 🙂
Opublikowany : 06/06/2022 6:40 pm
1 ludzie polubili
