Click Noise on Retractions ( not skipping... just faint click)
Christizzz
(@christizzz)
Is this retraction noise normal..i jsut noticed it on a model that requires a lot of retractions... https://drive.google.com/open?id=1a7vmKZHTTbr5arWghdcMW4rjHxQMP50x
Thanks
Veröffentlicht : 10/09/2018 9:07 pm
Robin
(@robin-4)
Re: Click Noise on Retractions ( not skipping... just faint click)
Probably the springs that tension the extruder gear side lid. If you watch the side that swings open you will see it moves in and out slightly are the extruder feeds and retracts. It sounds like a spring pinging
Veröffentlicht : 10/09/2018 9:12 pm
Christizzz
(@christizzz)
Thanks...so is it normal ? or should i do something ?
Support said it is nornal Retraction Noise... but still a bit worried 😁
Veröffentlicht : 10/09/2018 9:52 pm
toaf
 toaf
(@toaf)
it didn't sound that bad, do you think it could be from the nozzle rubbing the print abit? ive had a few times when odd noises came from that. I think after I calibrated the extrusion multiplier my noise got better. I still get one with heavy retractions. but all seems to work fine still
Veröffentlicht : 10/09/2018 10:10 pm
Christizzz
(@christizzz)
pretty sure its retractions ..but it does seem normal..but no one knows 😀
Veröffentlicht : 10/09/2018 10:12 pm
toaf
 toaf
(@toaf)
maybe your PTFE tube has come loose. it is really had to tell with that recording.
Veröffentlicht : 10/09/2018 10:42 pm
