Circular Prints Failing
Baron Opal
(@baron-opal)
Greetings!
Sadly, I am having difficulty with my sparkly new Mk3S. When I attempt to print a circular object it becomes terribly lopsided.
Circular test prints
(The above are relatively circular, not ovals as it appears.)
When I print a square, as I did with this Z-level test, it comes out okay.
I attempted to adjust the tension on the X and Y belts. The belt scores are X-243, Y-285. Oddly, they feel equivalently tense. I have loosened and retightened the belt gears. What else can I do?
Ce sujet a été modifié il y a 5 years par Baron Opal
Publié : 20/10/2020 7:56 pm
RE: Circular Prints Failing
re check your live Z settings...    the first layer looks bad.
Publié : 20/10/2020 8:06 pm
Posted by: @docopal-1
Greetings!
Here you will find valuable tips:
https://help.prusa3d.com/en/article/first-layer-issues_1804
Publié : 20/10/2020 8:38 pm
