Can't unload filament
mpeill
(@mpeill)
After a sucessful print, using the silver PLA supplied with the printer, I tried to unload the filament. This has worked on the few prints I've done so far, but this time the filament can't be unloaded. The display indicates that the hotend is rising in temperature to 215deg, then tells me to pull the filament out. However, it it still gripped strongly and won't come out.
Any ideas?
Opublikowany : 01/06/2019 9:35 am
mpeill
(@mpeill)
RE: Can't unload filament
Solved it. I opened the Extruder Idler door and found a blod at the end of the filament.
All is good again!
Opublikowany : 01/06/2019 1:36 pm
