Can't print
klimma
(@klimma)
Can't print
Hello, I recently got Prusa I3 mk3s, but I can't print anything. I have calibrated 1. layer, but every print after 1. layer fail. Where can be the problem? Thank you klims
Opublikowany : 10/07/2021 9:42 pm
RE: Can't print
Based on the first layer calibration, you might have your Z offset a little low.
Opublikowany : 11/07/2021 12:45 am
jsw
 jsw
(@jsw)
RE: Can't print
I would suggest a more rigorous Z calibration than the one in firmware.  You can get the Z 'dialed in' much closer than with the firmware cal routine.
There are several multi-square test prints that are very good for this purpose.
Opublikowany : 12/07/2021 10:59 pm
