Cant print anything
Names1
(@names1)
Cant print anything
Hi, need help cant print anything on my prusa i3 mk3
Calibrated the pind
did all the wizard thing
tried several times the first layer calibration
im getting out of ideas
https://drive.google.com/open?id=1C4LY4Eathda9pE2srV_xWvwKit9TZ_lH
Opublikowany : 16/04/2018 5:35 pm
Gato
 Gato
(@gato)
Re: Cant print anything
Not sticking. Bed looks clean. Try making z adjustment. Seems to be still to far from bed. Just in case make sure that bed is clean.
I’m assuming that you have your Pinda prove correctly adjusted using the zip tie method
Opublikowany : 16/04/2018 6:27 pm
Names1
(@names1)
yes i have, the z adjustment stucks to the bed no problem, problem is when printing, the carriage seems to be jumping when printing and the print not stucking
Opublikowany : 16/04/2018 7:43 pm
Nikolai
(@nikolai)
Have you tried to print the gcodes provided on the SD card?
Your first layer in the video IS to high. Live adjust Z until you can't barely see the plastic extruded. Then raise a little bit and see the difference.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 16/04/2018 7:59 pm
GertL
(@gertl)
Certainly looks like you are not low enough with live-z.
Try to lover that some more, more negative.
Gert
Opublikowany : 16/04/2018 8:04 pm
Names1
(@names1)
yes been printing the g.codes that was on the sd card, now im getting problems extruding
https://drive.google.com/open?id=1mNtcoQuHDRB6ZpFz1i0T_22luH9YJqr8
https://drive.google.com/open?id=1CPGNMvXyV63Ih3vcNksRJdrtTS-JgKhv
Opublikowany : 17/04/2018 2:46 pm
webshadow
(@webshadow)
looks like a halfjammed extruder if thats a real thing
are you sure the extrudergear is tight enough?
try extruding by moving the e-axis by hand (in the menu "move axis") and try to pinch the filament
with your finger really hard afaik it should be able to overcome the resistance
i think the z-height is ok since the layer looks ok where it DID extrude but better pictures might help
Opublikowany : 17/04/2018 3:23 pm
Names1
(@names1)
can this be because i can only screw 1 of the screws in this picture?
https://drive.google.com/open?id=1n1rLRAg0SyfY2U_hWdYww_mvvm1HjrAr
Opublikowany : 17/04/2018 8:03 pm
reid.b
(@reid-b)
That seems like a silly question... if your assembly is wrong, don't expect things to print properly.
Opublikowany : 17/04/2018 10:24 pm
Names1
(@names1)
its not that the assembly went wrong is that i can not screw that screw it always gets loose, maybe that part and problems in the print
Opublikowany : 17/04/2018 10:52 pm
Nikolai
(@nikolai)
No offence hugo, but if this screw gets loose, you did the assembly wrong! In this case nothing we can say will help you.
I would suggest you rebuild your extruder completely new. Take it apart and put it together. Make sure everything is EXACTLY by the guidelines.
No worries. This is how many of us are learning our loved 3d printer ....
Often linked posts:
Real Multi Material
Opublikowany : 18/04/2018 12:37 am
Names1
(@names1)
ok i will rebuild it again. sorry and thank you for your help
Opublikowany : 18/04/2018 1:20 am
RH_Dreambox
(@rh_dreambox)
If the screw loosens, you might want to check these nuts 😮
Opublikowany : 18/04/2018 12:23 pm
Names1
(@names1)
i gonna start the unusable now, thank you for the tips later i will put update
Opublikowany : 19/04/2018 2:30 pm
Names1
(@names1)
Not the perfect first layer but its printing thank you to all that help me if you ever come to portugal beer is on me 😀
https://drive.google.com/open?id=1oQ5RDV9Ucif5W2d_WI5fDGmaLuRfxRfD
https://drive.google.com/open?id=1Ugv6zT6AzpUFSCCRgV3Ki1zliLbKuhK7
edit: much better
https://drive.google.com/open?id=1DUzBGJq2DqW5Y4ZU7db4dKcNe7Qkkmdx
Opublikowany : 19/04/2018 11:40 pm
webshadow
(@webshadow)
Congrats 😀 during assembly i sometimes had the feeling something like that might happen to me too ...
Opublikowany : 24/04/2018 1:38 pm
