Can you calibrate without filament sensor
While waiting for support to respond I would like to go ahead with the initial calibration without the sensor. Since it fails on the filament sensor test, is there a way to calibration and bypass that step?
Postato : 02/06/2018 10:01 pm
Re: Can you calibrate without filament sensor
if you can select the calibration menu,
run
XYZ Calibration,
then run
Z calibration,
then run First layer calibration
Postato : 02/06/2018 11:17 pm
Topic starter
answered:
Thanks for the response Joan!!! I know it's probably documented somewhere, still getting familiar with the site.
Postato : 02/06/2018 11:24 pm
