Calibration XYZ Failed with MK3S Bear
Page 2 / 2
rmm200
(@rmm200)
RE: Calibration XYZ Failed with MK3S Bear
Those favors I mentioned? Person unnamed printed me up a full set of BNBSX parts.
Just sitting in a box waiting for me to have a reason to swap them in.
Publié : 16/03/2020 5:36 pm
graham_best
(@graham_best)
Posted by: @robert-rmm200
Nice. I put together the Bondtech version. What is the difference between the two?
Publié : 16/03/2020 7:41 pm
rmm200
(@rmm200)
As it turns out - Graham is one state over from me. So I can help him out.
Guy is a world expert on Bear - maybe he can help with the differences. Lots of other folks here have also built all versions.
I would think any BondTech variation would be confined to the extruder. Bear or Bear Short End ends are pretty standard.
Publié : 16/03/2020 8:02 pm
PGe-10
(@pge-10)
@peter-k42
Thanks peter-k42, now it worked perfectly.
Your help fixed my problem and it is obvious that I did not read everything that I should have done for this information has completely passed me by. A follow-up question you may know, I have to put on Gregsaun's firmware every time I need to do this calibration?
Publié : 06/04/2020 12:09 pm
graham_best
(@graham_best)
@peter-k42
Yes, I needed to run the calibration with the special Bear firmware. Thank you for your help!
I guess I missed that as I was trying to use a different instruction set to assemble the Prusa i3 MK3S Bear upgrade.
Publié : 02/05/2020 11:22 pm
Page 2 / 2
