Calibration problem in first layers
SteveS
(@steves-2)
Hi, all. Just completed my build and have printed a couple of test items.
The problem I seem to be having is that the first 3 or 4 layers are loose, as if the extruder is too high. Then subsequent layers tighten up. I have a sense that the calibration is not quite right, but I'm not sure exactly what to do about it. I've attached a pic.
Thanks in advance for any advice--
-Steve
Opublikowany : 05/12/2018 3:53 am
SteveS
(@steves-2)
Re: Calibration problem in first layers
I've fixed this particular problem. There still seems to be a tiny bit of offset in the front to back direction between the first few and subsequent layers, but I think it's a matter of correct tension on the Y belt.
Opublikowany : 07/12/2018 3:33 pm
