[Solved] Calibration issues after i3S+upgrade
RickSeiden
(@rickseiden)
Hello,
I bought my printer as a MK3 i3 kit, assembled it myself and got it printing with no problem.
Then I upgraded it to the MK3S myself, and got it printing no problem.
Now I've upgraded it to the MK3S+, and I have problems.
To start with, the X-axis length test said it was the wrong length, and the bed would make crashing noises when I tried the XYZ/SuperPINDA calibration (where you hold the paper under he nozzle).  First I verified I had the right firmware on there (3S not 3), and I did, so I did more troubleshooting and decided to reload the firmware anyway, just to be 110% sure it was 3S and not 3. Now I know that the firmware is the right version (3.9.3-3556 for the 3S/3S+).  So I do more troubleshooting, more calibration attempts, always getting failures.
I read in the knowledge base to do a full factory reset, so I do that, and start the calibration.  The X-axis is now apparently the correct length, because that works, but the Y-Axis/bed says to check the Y-axis length.
Here's a YouTube video showing what happens.
I'd appreciate any help anyone can give.
Thanks
Rick
Napsal : 13/02/2021 3:17 pm
RickSeiden
(@rickseiden)
RE: Calibration issues after i3S+upgrade
As Adam Savage is known to say, "There's your problem!"
I have no idea how that magnet managed to make it there, but having a magnet there would cause the Y-axis to appear shorter!
Napsal : 13/02/2021 9:13 pm
Dragon1291
(@dragon1291)
@rickseiden
Looks like one of the bed magnets.
Napsal : 14/02/2021 12:02 am
RickSeiden
(@rickseiden)
I think it was one of the filament sensor magnets.  I must have dropped it and it got attached under there. Or maybe it was on my work surface when I flipped the printer on its side to upgrade the u bolts to the brackets.
Napsal : 14/02/2021 12:30 am
