Calibration failed (loop) after "Sorting Files"
Hello,
I just finished assembling my printer ...
- At the start, the wizard asks me if I want to be guided, I answer Yes
- The printer displays a "Sorting Files" message with a progress bar for 1/2 second
- Then it loops back to the message "Hi, I am your original ..."
In the meantime the two fans have turned (and stopped), the probe turns red (and turns off if I approach a metal part).
What should I do, I'm a little helpless ...
PS I specify that I tried to update the firmware with the proposed procedure, and the firmware seems to have been updated correctly (prusa3d_fw_MK3_3_5_0.hex).
Opublikowany : 20/12/2018 5:25 pm
Re: Calibration failed (loop) after "Sorting Files"
I would guess you are pressing the X “reset” rather than depressing the knob itself which is how you make selections.
Hope that helps!
Opublikowany : 20/12/2018 6:22 pm
Topic starter
answered:
Oups!
Thank you
Opublikowany : 20/12/2018 8:16 pm
