Calibration Cube Z-Height
Chris
(@chris-12)
Hello All,
After some searching online and on this forum i can't seem to find a topic related to this issue. Here it goes:
When i print a Calibration Cube https://www.thingiverse.com/thing:1278865 the Z height doesn't seem accurate compared to the X and Y.
Printed in PLA, 0.2 layerheigt, 20% infill, 45mm/s. Extruder 210C, Bed 60C
X Meassure's 20mm dead on
Y messures's 20mm dead on.
Z measurres 20.2mm
1. Did Z Calibration
2. I started with checking Live Z adjust on my first layer, i ran the "Z Adjust my way" and got it nice smooth surface. Seems good.
3. I checked forum's and found out i need to calibrate Extruder; Measure software distance G1 E100 F100 vs filament distance. Got it dead on again
after some adjustments.
4. Lastly i printed the extrusion multipier Calibration Cube (40x40x40) to measure the average wall thickness, it was a little off. However i measured the
Z height of the Cube and it was 40mm dead on, X 40mm, and Y 40mm..
the Miltiplier Calibration cube however is a Prusa generated Gcode file. The XYZ Calibration Cube's i sliced myself with Slic3r. I got a feeling it has to do with the Slicing or the fact the XYZ-Calibration cube has a thicker layerthickness then 1 and thus has something to do with the Z-Height.
How can i get my calibration Cube Z height to 20mm? The Extrusion multipier cube is however only 1 layer thick. does this have something to do with the accuracy?
Thanks in advance.
Respondido : 24/08/2018 1:14 pm
thrawn86
(@thrawn86)
Re: Calibration Cube Z-Height
pic?
.1 or so really isn't anything to write home about with fdm printers, but there are plenty things that could affect your dimensions.
Respondido : 25/08/2018 6:35 am
1 les gusta
