Building the Y-Axis
Matt
 Matt
(@matt-4)
Building the Y-Axis
is this normal? Everything seems to be aligned, all 4 corners are stable, belt is taught but it does this. Is it binding? I'm not pushing hard, very gently.
Este debate ha sido modificado el hace 6 years por Matt
Respondido : 25/09/2020 5:55 am
GKMAKEIT
(@gkmakeit)
RE: Building the Y-Axis
Use process of elimination, what happens if the belt is off? Also try loosening the nuts on the ubolts.
Esta publicación ha sido modificada el hace 6 years por GKMAKEIT
Respondido : 25/09/2020 7:27 pm
Lynng
(@lynng)
You are feeling the resistance of the stepper motor.  As GKMAKEIT suggested, when you take off the belt you will notice all that resistance goes away.  There are magnets in the stepper motor that are coming into and going out of position with the motor rotor and that creates the resistance.  By the way when you move any stepper motor like that, you are actually creating voltage at the coil outputs.  That can damage your electronics, so be careful not to do that when you are all hooked up without doing a motor off command first.
Respondido : 27/12/2020 1:47 pm
Alan B.
(@alan-b)
You might want to make sure that the bolts on the bearing retainers aren't too tight.  Overtightening them can cause the bearings to bind.
Respondido : 28/12/2020 4:26 am
