boot recycling
reesys
(@reesys)
boot recycling
Finished build, first turn on - looks to boot ok, fans run etc, get to choose language - select one, then it recycles back to choose language
downdated firmware to 3.8.1  - same thing, re-updated back to 3.9.2 and not resolved.
if put in SD card, it sorts files and lets you pick, then goes back into same loop
Best Answer by RH_Dreambox:
You are probably pressing the reset button (X).
Press the rotary knob and it will work.
Opublikowany : 31/12/2020 2:33 pm
RH_Dreambox
(@rh_dreambox)
RE: boot recycling
Opublikowany : 31/12/2020 3:30 pm
reesys
(@reesys)
RE: boot recycling
proper noob error, *blush*
thanks
Opublikowany : 31/12/2020 4:07 pm
