Black plastic collet
eng.shaimaa.elsersy
(@eng-shaimaa-elsersy)
Hello ,
I have a problem since March , I discovered that the problem is related to PTFE Prusa , finally I realized that the problem is related to black plastic collet . When I pulled the collet out , it returned back inside the Hotend , so i stucked in a thin iron to prevent the collet from sliding again inside the Hotend .So what happens is the following: when i go ahead to print i found that it printed some layers and then stopped then i made unload & load filament : i had to force  the filament inside the hotend to get out of the nozzle Then when i pressed printing : the same issue happened which is printing some layers and stopped again . What can I do ? Thanks .
Veröffentlicht : 21/05/2021 7:43 pm
Mitglied
RE: Black plastic collet
You can buy a new hotend or a replacement collet.
Veröffentlicht : 21/05/2021 7:59 pm
eng.shaimaa.elsersy
@cwbullet
Thank you
Veröffentlicht : 21/05/2021 8:32 pm
I'm still trying to figure out what collet your are talking about. Is it this collet?
You can install the locking pin to keep it from moving.
Together they look like this:
https://www.thingiverse.com/thing:3499966
Diese r Beitrag wurde geändert Vor 5 years 3 mal von --
Veröffentlicht : 22/05/2021 12:18 am
Mitglied
https://e3d-online.com/products/embedded-bowden-collet-for-metal-1-75mm
Veröffentlicht : 22/05/2021 12:21 am
eng.shaimaa.elsersy
@tim-2
Thank you , yeah my prusa is MK3S , i print the file from Thingiverse , as i said that it prints but for the first layers only or as soon as the file is small , but i want to know this collet you have sent is ok for PRUSA MK3S  ?
Veröffentlicht : 22/05/2021 2:00 pm
Mitglied
Make sure you do a high infill like 100%
Veröffentlicht : 22/05/2021 2:11 pm
eng.shaimaa.elsersy
Yeah , i did the infill 100 % ,thank you.
Concerning your link , is the collet in your link fits Prusa MK3S ?
Veröffentlicht : 22/05/2021 2:15 pm
Mitglied
Yes as long as you get the 1.75mm
Veröffentlicht : 22/05/2021 2:16 pm
eng.shaimaa.elsersy
Ok , Thanks A lot .
Veröffentlicht : 22/05/2021 2:18 pm
The collet clip should fit any of the metal E3D-V6 hot ends. So yes, it should fit your Mk3S.  If in doubt, purchase a new clip from E3D.
You can shop around to find them locally.
Here they are on E3D's site.
https://e3d-online.com/products/collet-clips-pack-of-2
Here's the ones on Amazon (expensive).
https://www.amazon.com/Genuine-E3D-Collet-1-75mm-M-BOWDEN-CLIP-175/dp/B07B68DBS6
ps: and one more version on Thingiverse: https://www.thingiverse.com/thing:2585970
Diese r Beitrag wurde geändert Vor 5 years 2 mal von --
Veröffentlicht : 22/05/2021 3:05 pm
Mitglied
Did your printed collet work?
Veröffentlicht : 23/05/2021 12:14 pm
eng.shaimaa.elsersy
@tim-2
Thank you
Veröffentlicht : 23/05/2021 12:54 pm
eng.shaimaa.elsersy
@cwbullet
yeah , I printed it and I inserted it under the plastic collet though part of it was broken during stucking it in because it is a little fragile .
I am doing calibration now , if  does not print , i will buy it and the plastic black collet , thank you .
Veröffentlicht : 23/05/2021 1:09 pm
Mitglied
It will work.  Just to clarify, which part broke - black or blue.  I was 100 percent certain it was the black part before, but rereading, I am not so sure.
Veröffentlicht : 23/05/2021 1:40 pm
eng.shaimaa.elsersy
Sorry , I mean the blue Plastic part which i printed from Thingiverse , small part of it was broken .
Veröffentlicht : 23/05/2021 1:50 pm
Mitglied
Ok.  I have had to replace both once.  That is a Collet Clip.
Veröffentlicht : 23/05/2021 2:11 pm
eng.shaimaa.elsersy
Yeah you are right . Unfortunately I replaced both once but lately after part of it was broken , any way it prints now as shown in the photo , i am going to try large prints .
Thank you
Veröffentlicht : 23/05/2021 4:06 pm
Mitglied
That is success in my book! 😀
Veröffentlicht : 23/05/2021 4:27 pm
eng.shaimaa.elsersy
@cwbullet
Thank you 🙂
Veröffentlicht : 23/05/2021 6:16 pm
