Benchy Print Issue (First Print)
This is the first print I did on the printer. I ran the setup. This is from the second MK3S I have. The first one prints perfectly. When I ran the setup it said the axis was perfectly square. I am using a default prusa PLA settings with quality 0.15 layer height settings. I used the same gcode for both printers and the print on prusa 1 was perfect and that was the result on prusa 2. Should I just rerun the first time setup or what should I do?
Veröffentlicht : 18/01/2020 5:21 pm
RE: Benchy Print Issue (First Print)
First check your pulleys if they are lose
Veröffentlicht : 18/01/2020 5:46 pm
Printing a new test print. Thank you for the help
Veröffentlicht : 18/01/2020 7:32 pm
