Belt Tension Too Tight
Bill H
(@bill-h)
I have just started to build my Prusa i3 Mk3 S+ and need some assistance / advice.
When installing the first belt holder I left about 10mm of belt overhanging. However when I went to fit the second belt holder, there was not enough slack and I could not screw the belt holder to the Y carriage. I undid the screw holding the belt onto the first belt holder and re did it so that it only overlapped by about two teeth. This still was not enough so I had to undo the Y Belt Idler Bracket which then allowed me to fit the second Y Belt Holder?
After securing the Y Belt Holder bracket and then the Y Belt Idler bracket the belt seem really tight? Should I have a longer belt?
Here is a video and pictures.
Y Belt Tension
Postato : 13/03/2021 2:00 pm
Clarmrrsn
(@clarmrrsn)
RE: Belt Tension Too Tight
That looks way too tight
Both parts of the belt should both be just within the printed part like this, are you using the online manual, its far easier to follow.
Prusa Knowledge Base (prusa3d.com)
You need to take both ends back a few notches on the belt
Questo post è stato modificato 4 years fa 4 tempo da Clarmrrsn
Tank you very much!
Postato : 13/03/2021 5:06 pm
Clarmrrsn
(@clarmrrsn)
Or maybe just one tooth on each side, but certainly looks too tight to me.
"Make sure the bent part and the end are within the width of the printed part"
Y-axis: Assembling the belt
Tank you very much!
Postato : 13/03/2021 5:14 pm
Bill H
(@bill-h)
Undid the belts and shortened up the amount in the tensioner, all good now and tensions using the long screw as designed 🙂
Postato : 16/03/2021 10:02 pm
Clarmrrsn
(@clarmrrsn)
Good news.
Tank you very much!
Postato : 16/03/2021 10:48 pm
Technical Ted
(@technical-ted)
When you get it fully assembled and operational there is a menu selection that displays a value of the tension measured during the calibration routine. See the 3d printing handbook.
Ted
Postato : 16/03/2021 11:29 pm
Bill H hanno apprezzato
