Beginner questions
Cycleman
(@cycleman)
Beginner questions
hey guys... I am new here. I just buy th mk3s complete. I am happy with that!!!!
I have some questions. First of all the the calibration. I put off the sheet and I just hold a paper and leave the machine to make the rest. After that I make the first layer calibration. I don't know which is the best. I make some to compare with 1.350,1.300,1.250,1.200. I see good layer in 1.300 but I don't know if is this thin. Some times with 1.250 I have not sticky print in bed so the stuff come off while printing. This may be my room because I live In island.
My 2nd questions is I must do something after a while with oils or something. I didn't read something in manual. I am not a manual guy so maybe I pass it.
The last one (for now 🙂 ) is that I want to enclosure that thing. I lake diy enclosure with ikea. As I read the psu suffers from hot temps so I must put in out. In thingiverse I found some but as I see is not for mk3s Have anybody find something with good results?! do I need extra screws?!
Thanx a lot.
Publié : 14/02/2021 10:56 am
Membre
RE: Beginner questions
Pictures might help.  What about -1.275?
Publié : 15/02/2021 2:27 pm
Cycleman
(@cycleman)
pla temp 60 in bed 215 on nozzle.
Publié : 15/02/2021 5:30 pm
Resty
(@resty-2)
Simple question, when doing the first layer calibration should the extruder fan be running?
I ask because the three times I have tried to do this the PTFE tube blocks due to heat creap.
The print fan is running but not the extruder. MK3S. Latest firmware.
Publié : 15/02/2021 6:58 pm
Baklin
(@baklin)
Posted by: @resty-2
Yes. The extruder fan has to be running. (the Noctua fan on the left) This fan always runs when the extruder temp is above 50 C.
Publié : 15/02/2021 7:19 pm
Cycleman
(@cycleman)
any thoughts?!
Publié : 15/02/2021 9:05 pm
Membre
I would check the connection and wires. I would also check with a second fan.
Publié : 15/02/2021 9:32 pm
Resty
(@resty)
Thanks guys, solved. 😀
Fans were connected the wrong way round, I didn't understand what the different names ment.
Publié : 16/02/2021 1:03 am
Membre
@resty
Rest assured, you are not the first and you will not be the last to do that.
Publié : 16/02/2021 1:08 am
