Bed Leveling Print Messed Up
clx
 clx
(@clx)
Hi everyone,
I just got the MK3S+, tried printing the official bed leveling model resulted in a heavily scarred center square and acceptable middle right and lower left corner.  Is this a bed leveling problem, or something else (belt tension, warp bed plate, etc…)?
Thanks for any insight!
Opublikowany : 31/08/2021 4:27 pm
Baklin
(@baklin)
To me that looks like the nozzle needs to be closer to the bed and maybe clean the bed.
Clean the bed with dish soap and lots of hot water.
Opublikowany : 31/08/2021 5:42 pm
Dan Rogers
(@dan-rogers)
Nothing about any of those look acceptable to me.  Advice = hot soapy water, handle only by edges. Then enable 7x7 bed mesh leveling in the settings.  Then read life adjust Z my way thread.
Opublikowany : 01/09/2021 11:20 am
clx
 clx
(@clx)
Nylock Bed Leveling?
Soap washed &  alcohol wiped the bed, a little better but still seeing similar result where the square in middle of the bed has large gaps and the sides of the bed has smaller/none gaps.  Thinking about doing the nylock bed leveling mod, is that still recommended for MK3S+?
Opublikowany : 01/09/2021 3:32 pm
