Bed hot zone cable came out
TechDaddy
(@techdaddy)
Hello -
In troubleshooting some issue with layer shifting, I took off the bed to try to loosen the belt and bearing U bolts a bit to see if I could make the bed move more smoothly on the Y-Axis.
Unfortunately, while attempting to troubleshoot this, the cable that goes underneath the tape to the hot end came out and the bed is no longer heating. In looking through the Prusa store, I don't see any replacement tape that I could use to put the cable back where it is supposed to go. Does anyone have any tips on what tape I'd need to put it back in place safely?
Thanks in advance!
Respondido : 06/01/2019 12:28 am
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: Bed hot zone cable came out
https://smile.amazon.com/Hxtape-Temperature-Polyimide-Printing-Soldering/dp/B07DBZ1SW6/ref=sr_1_1_sspa?ie=UTF8&qid=1546746125&sr=8-1-spons&keywords=capton%2Btape&th=1
Hxtape High Temperature Kapton Tape,Polyimide Film Tape to Masking,3D Printing,Electric Task,Soldering,1/2 inch(12mm),36yds $5.68
Respondido : 06/01/2019 4:44 am
