Batman holes / craters on the top layer
Pagina 1 / 3
dark_NES
(@dark_nes)
Used to work great, now I keep getting these holes in the top layer of the ol' Batman print like it took a meteor attack. I can't find anything online about this particular malady.
Calibrated it a million times and the First Layer Z calibration test comes out bang-on. Help a guy out?
Postato : 26/03/2021 2:41 am
Antonio
(@antonio)
Utenti Moderator
RE: Batman holes / craters on the top layer
try to set an higher number on top layers ( 5 top layers) . that should solve the issue
I'm not an expert. Ma parlo anche italiano 😉
Postato : 26/03/2021 8:52 am
dark_NES
(@dark_nes)
@antonio-da-catania
Thanks so much for responding!
This is just the standard "Batman" model that comes with the printer, so the top layer is already set to 5 out of the box, but I suppose I could increase it. If it used to work fine without me changing any of the settings, might you know if there's a common cause for this new issue?
(Cleaned the bed with dish soap and deionized water, all the stuff you find online)
Postato : 26/03/2021 10:28 am
Antonio
(@antonio)
Utenti Moderator
That's interesting! Need more investigation.
Ok the model (batarang) is the same, but are you printing the very same g-code file you found on the SD card? Or is it a new slice?
Also, i'm not sure at this point. The surface with the issue is the first layer (in contact with the bed)? or is it the last layer (the top layer) ?
Postato : 26/03/2021 10:37 am
dark_NES
(@dark_nes)
@antonio-da-catania
It's a bat-mystery!
It's just the same old model that comes on the SD card, haven't touched it.
And this the top layer (i.e. the last layer printed).
Postato : 26/03/2021 10:41 am
Antonio
(@antonio)
Utenti Moderator
may you send me the same gcode ?
Postato : 26/03/2021 10:46 am
dark_NES
(@dark_nes)
@antonio-da-catania
Yeah, man, can do, but it's really just the stock standard, pre-packaged model:
https://www.dropbox.com/s/enfqmmsqaaiu7o0/MK3_PLA_Batman_200um_18M.gcode?dl=0
Postato : 26/03/2021 10:58 am
Antonio
(@antonio)
Utenti Moderator
the file it's fine.
So maybe It could be a partial clog of the nozzle or maybe due (unlikely) the bondtech gear loose.
give it a look at this and this articles
Postato : 26/03/2021 11:06 am
dark_NES
(@dark_nes)
@antonio-da-catania
Whoa, okay, cool. Definitely something to try, thank you!
Postato : 26/03/2021 11:27 am
Does this happen with other filaments?
It's hard to tell from the picture; is there some discolouration around the bad spots?
The nearest I have seen to this occurred after some milk (at least, I suspect it was milk) was splattered onto a spool of PLA and as each soiled spot passed the nozzle it prevented adhesion locally.  Having said that I've not seen it on a top layer so I'm partly guessing here.
Postato : 26/03/2021 11:41 am
dark_NES
(@dark_nes)
@diem
Hey, thanks for taking a look at it. Yeah, it happens with a number of different filaments, unfortunately.
Postato : 26/03/2021 12:15 pm
Antonio
(@antonio)
Utenti Moderator
I'm still thinking about it...
can you post a clearer picture?
also, just to be extra sure 😅: what we see in the picture is the 5th layer of the five top layers, right?
Postato : 26/03/2021 12:21 pm
dark_NES
(@dark_nes)
@antonio-da-catania
Yes, it's the top layer.
This is how it looks when the print finishes:
Postato : 26/03/2021 1:01 pm
dark_NES
(@dark_nes)
Unfortunately, a cold pull did not resolve the issue.
Postato : 26/03/2021 6:15 pm
3Delight
(@3delight)
Moderatore Moderator
This looks like pillowing, usually caused by incorrect cooling of the top most layer.  The fact that we all have the same GCODE and it works for most suggests there is either something wrong with your fan setup, that you've got a draft where the printer is, or that the room where it is is excessively cold or hot.  Check that the fans are connected to the right headers (IE not swapped over) and that they are working OK.  If it's an environmental issue you may need to build/buy an enclosure (assuming it's not just that you left a window open nearby)...
Postato : 26/03/2021 6:45 pm
dark_NES
(@dark_nes)
Pillowing - Okay, this is the vocabulary word I didn't have, so thanks times the universe for that.
Unfortunately, self test runs fine on fans and really nothing has changed the room. Maybe it's factory reset time?
Postato : 26/03/2021 7:27 pm
Technical Ted
(@technical-ted)
I'm newer to this so take this with a grain of salt, but how are your filament drive gears? Are they clean or all loaded up? How is the tension on the idler gear? Is it driving properly? Maybe it's under extruding???
Ted
Postato : 26/03/2021 7:38 pm
3Delight
(@3delight)
Posted by: @dark_nes
Yes, I would do a factory reset, calibration, and first layer adjustment, and  then do another print watching carefully as it prints that last layer and watch for absolutely anything amiss.
RE: Pillowing, have a look at these couple of sites, then do a google search for "3D print pillowing" (without the quotes):
https://pick3dprinter.com/3d-printing-pillowing/
https://support.ultimaker.com/hc/en-us/articles/360012016240-How-to-fix-pillowing
Postato : 26/03/2021 7:57 pm
Antonio
(@antonio)
Utenti Moderator
There is the acupuncture option:
1)preheat the nozzle to the filament temp (or even hotter , in ex. 260°C for PLA) .
2)Lift the extruder up to 150mm or more (for better visibility).
3)From the menu -> settings -> move axis -> Extruder ->rotate the knob to the right to extrude the filament
keep an eye on the nozzle.
if the filament is extruded straight, the nozzle should be fine.
If the filament comes out curling and twisting, it is partially clogged.
in the latter case, use an acupuncture needle to try to unclog it from below (inserting the needle in the nozzle from the extrusion hole)
Postato : 26/03/2021 8:32 pm
3Delight
(@3delight)
I can't imagine it's a clog as dark_NES says the rest of the layers always print correctly.  I still think it's pillowing.
@dark_NES: Have you checked that it is printing at 100% speed as set on the LCD?  Printing too fast can also cause pillowing.
If you look at this example of pillowing:
and compare it to dark_NES's sample:
You can see that they are the same...
The main factors that cause it are incorrect cooling, too fast printing, and too few top layers.  It can very occasionally be caused by the nozzle being too near the bed so raising the Live Z by a couple of steps may help if nothing else does.
Postato : 26/03/2021 8:57 pm
Pagina 1 / 3
