Back right corner too low - Images
Steverd
(@steverd)
The back right corner on my MK3S+ seems to be a bit too low - see images.
This is my 1st MK3S+, less than a month old and assembled by Prusa.
I imagine I need to square up something, but I need your guidance.
Do you think the "X" or "Y" is off?
What is my next step? Thank you so much!
Opublikowany : 13/01/2022 12:45 pm
Thomas
(@thomas-14)
RE: Back right corner too low - Images
I can’t tell from the pictures what you need  to square up, if anything,, but it does look to me like your first layer calibration is too low (too negative).
Opublikowany : 13/01/2022 12:55 pm
Try enabling 7x7 mesh bed levelling - LCD menu.
Opublikowany : 13/01/2022 1:07 pm
1 ludzie polubili
Marvin
(@marvin)
Try xyz calibration, https://help.prusa3d.com/en/article/xyz-calibration-mk3-mk3s-mk3s_112351
I'm not sure if this will catch your problem, but should be a good start.
7x7 calibration should mitigate the problem the print bed will still be skewed.
Opublikowany : 13/01/2022 1:19 pm
1 ludzie polubili
Steverd
(@steverd)
Yes - but ONLY in that back corner the rest is good.
Posted by: @thomas-14
Opublikowany : 13/01/2022 6:20 pm
Steverd
(@steverd)
This one change completely FIXED my issue - Thank you
Posted by: @diem
Opublikowany : 14/01/2022 9:24 pm
