Back right corner too low - Images
The back right corner on my MK3S+ seems to be a bit too low - see images.
This is my 1st MK3S+, less than a month old and assembled by Prusa.
I imagine I need to square up something, but I need your guidance.
Do you think the "X" or "Y" is off?
What is my next step? Thank you so much!
RE: Back right corner too low - Images
I can’t tell from the pictures what you need to square up, if anything,, but it does look to me like your first layer calibration is too low (too negative).
Try enabling 7x7 mesh bed levelling - LCD menu.
Try xyz calibration, https://help.prusa3d.com/en/article/xyz-calibration-mk3-mk3s-mk3s_112351
I'm not sure if this will catch your problem, but should be a good start.
7x7 calibration should mitigate the problem the print bed will still be skewed.
Yes - but ONLY in that back corner the rest is good.
This one change completely FIXED my issue - Thank you
