[Solved] Axis problem, weird printing
odo3d
(@odo3d)
Hello, really need your help, i recently print this benchy, and after multiple callibration all seems fine, but whe i print, this weird problem is happening, the X axis seem to be bugged, but it worked fine just a week ago, does some one knowwhatis the problem please ?
thanks a lot !
Napsal : 09/08/2023 8:33 pm
Robin_13
(@robin_13)
RE: Axis problem, weird printing
Did this happen again?
I wonder if your drive on your axis slipped.  Ensure that the one of the set screws on the belt drive is on the flat on the motor shaft and that they are snug.  Don't over tighten them.
Also confirm you belt tension is correct.
Napsal : 13/08/2023 7:10 pm
1 lidem se líbí
odo3d
(@odo3d)
yap, you are totaly correct, i solved the problem same day i posted it here but totally forgot to delet my post hehe, thanks !
Napsal : 14/08/2023 12:03 am
