Awful First Printing
Inbar
(@inbar)
Does anyone have an idea what could go wrong? The wizard said everything was fine and I tried to calibrate the z axis many times..
Best Answer by Steve:
I agree. Something is loose. Belts loose enough to cause that much error should be obvious. The next place to check is the set screw on the motor pulleys.
Ce sujet a été modifié il y a 6 years par Inbar
Publié : 12/08/2020 6:56 pm
RH_Dreambox
(@rh_dreambox)
RE: Awful First Printing
Check that the X and Y belts are correctly tensioned. Loosely tensioned straps can cause a very poor finish.
Also check that the drive wheels (timing belts) are securely fastened and do not come loose.
Publié : 14/08/2020 3:02 pm
1 personnes ont aimé
Steve
(@steve-3)
Publié : 14/08/2020 6:33 pm
Inbar
(@inbar)
Apparently a screw in the Y axis was not tight enough. Amazing how one screw can change everything.
Publié : 15/08/2020 12:24 pm
Inbar
(@inbar)
@steven-p8
Thank you!!
Publié : 15/08/2020 12:26 pm
Inbar
(@inbar)
@rhdreambox
Thank you!!!
