Awful First Printing
Inbar
(@inbar)
Does anyone have an idea what could go wrong? The wizard said everything was fine and I tried to calibrate the z axis many times..
Best Answer by Steve:
I agree. Something is loose. Belts loose enough to cause that much error should be obvious. The next place to check is the set screw on the motor pulleys.
This topic was modified před 5 years by Inbar
Napsal : 12/08/2020 6:56 pm
RH_Dreambox
(@rh_dreambox)
RE: Awful First Printing
Check that the X and Y belts are correctly tensioned. Loosely tensioned straps can cause a very poor finish.
Also check that the drive wheels (timing belts) are securely fastened and do not come loose.
Napsal : 14/08/2020 3:02 pm
1 lidem se líbí
Steve
(@steve-3)
Napsal : 14/08/2020 6:33 pm
1 lidem se líbí
Inbar
(@inbar)
Apparently a screw in the Y axis was not tight enough. Amazing how one screw can change everything.
Napsal : 15/08/2020 12:24 pm
Inbar
(@inbar)
@steven-p8
Thank you!!
Napsal : 15/08/2020 12:26 pm
Inbar
(@inbar)
@rhdreambox
Thank you!!!
