Automatic bed leveling not working?
Dull Soldering
(@dull-soldering)
My first layer gets squished on the top left of the printbed. While it almost seems too high in the middle and bottom right.
What could be causing this, and how can I fix it or at least diagnose it further?
Publié : 30/07/2021 2:54 pm
Peter M
(@peter-m)
RE: Automatic bed leveling not working?
What happened before this, you give no info?
What did you do to resolve this?
If you move the printer or had a crash, do a z-calibration, with a heated bed and nozzle.
Clean nozzle? Extruder to loose, check the whole printer on loose bolts, screws etc.
7x7 mesh leveling, this is a setting in the printer,is better then the 3x3.
Steel sheet not good on the bed.
Ce message a été modifié il y a 5 years par Peter M
Publié : 30/07/2021 6:21 pm
