Autoload not working, but will work for manual loading.
Rub3do
(@rub3do)
I had a filament jam recently where I needed to remove the PTFE tube to clear out the jam.  Afterwards after putting the extruder back together the autoload filament function does not work anymore.  When I insert filament it doesn't even try to pull the filament in.  It does work however for manually loading it.
I assume its a sensor issues but I'm not sure what to troubleshoot first on this.
Postato : 22/11/2019 4:52 pm
rmm200
(@rmm200)
RE: Autoload not working, but will work for manual loading.
In Settings turn the sensor off.
That will let you print; just tell it to load filament.
At your leisure you can figure out what is wrong with the sensor.
Postato : 22/11/2019 6:35 pm
