Assembly Finished - Unable to feed filament into the extruder
pdirezze
(@pdirezze)
When I get to the part of the setup wizard where I'm supposed to insert filament into the extruder, the ABS filament goes in about 1 cm and stops or seems blocked. I jiggle the filament but no luck. How do I diagnose this problem?  How do I take apart the extruder while it's on the printer?
Opublikowany : 02/10/2020 3:59 am
RE: Assembly Finished - Unable to feed filament into the extruder
Posted by: @pdirezze
As so often a problem that the filament sensor is not properly adjusted. Check the status on the LCD. Filament loaded = 1, not loaded = 0.
https://help.prusa3d.com/en/article/filament-sensor-mk3-non-s_2125
Opublikowany : 02/10/2020 11:05 am
The top problem I see if the magnets being in wrong or the screw holding the sensor being too tight.
Opublikowany : 02/10/2020 11:09 am
pdirezze
(@pdirezze)
@karl-herbert
Thanks for the prompt response but this was my mistake. I put the extruder idler wheel in backwards. I've fixed and calibrated it and am printing some test prints.
No IR sensor hassles here (yet)
Thanks again for your help.
Opublikowany : 02/10/2020 1:28 pm
Awesome! - I love to see success.
Opublikowany : 02/10/2020 4:54 pm
@pdirezze
Don't get it wrong, but usually the problem is in front of the printer. At least it is with me 👍
happy printing!
Opublikowany : 02/10/2020 6:09 pm
pdirezze
(@pdirezze)
I just wanted to add a thakyou to the folks who set up your 360 degree viewer
https://www.prusa3d.com/mk3s-360-viewer/
It really helped diagnose my issue.
Opublikowany : 03/10/2020 3:06 pm
1 ludzie polubili
